Peter BENSCH
Peter BENSCHBest answer
We know that this is inconvenient, especially for small system quantities. But yes, to be Bluetooth compliant requires both registration with the BT SIG and the corresponding payment of licence fees, which are incurred per new project. Details can be found on the BT SIG website you mentioned.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
SSmit.13
SSmit.13Author
Senior
May 2, 2023
Thanks Peter.
Unfortunately the approx $5k per project for just to use bluetooth is far to expensive for our projects. We will use WiFi .
Best Regards
Scott
Peter BENSCH
When the problem is solved resp. the question answered, even if it doesn't quite meet your expectations, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
Good luck!
/Peter
