Do I have to add a pull-up resistor to the reset circuit of STM32WB55 MCU?
2021-05-25 12:03 AM
I would like to use a reset circuit with a push-button for STM32WB55 MCU. The datasheet of the MCU gives a diagram which is uploaded to the attachment. As I understand, I use just a push-button and a capacitor. VDD and pull-up resistor is involved internally.
But, in many example schematics which is published by ST shows that there are a pull-up resistor and VDD connection externally. And sure, the circuit is connected by an active-low signal. So, I need a VDD with a pull-up resistor.
The question is that whether I have to use a VDD connection with a pull-up resistor in the reset circuit or not necessary.
Thank you,
Batuhan
- Labels:
RESET
STM32WB series
2021-05-25 12:11 AM
Hi @Batuhan A. ,
There is no need for a pull up for nreset:
please have a look on stm32wl-nucleo board:
Best Regards
2021-05-25 12:11 AM
Hi @Batuhan A. ,
Best Regards
2021-05-25 12:19 AM
Hi, thank you for your comment,
The second schematic image is from "STM32WB55 USB Dongle" published by ST. It was confusing me.
I had a look at the STM32WL Nucleo board schematics. I do not use the pull-up resistor.
This is the relevant part of the board for other people for a quick check.
