arun rajajinagar
Code Get Stuck
  • July 17, 2019
  • 1719 views
I am using STM32L072 LoRa discovery kit and enabled UART with DMA. Some times my code gets stuck in HAL_UART_Receive_DMA( ....) function at the line
SET_BIT(huart->Instance->CR3, USART_CR3_EIE);
This is called at the begining of the code. It wont recover at all until i reset the MCU for some number of times.
Kindly let me know how shall I resolve this issue.
Tesla DeLorean
Guru
July 17, 2019
Make sure you check and clear any noise or framing errors, etc that might be stopping the receiver from collection additional data.
Implement a timeout/recovery so it doesn't get stuck indefinitely. You'll likely need to debug/diagnose your own system.
MSipo
Senior II
September 25, 2023
