2025-03-03 7:24 AM
Hello
I have a question, please. I am planning to use a Bluetooth module, and since I am required to apply potting, could you let me know which antenna is less affected by it: the chip antenna or the PCB antenna?
thanks
2025-03-27 7:54 AM
Hello @ljm
This may depend on the antenna you are going to use. So, the best way is to test all use cases and try to find the suitable one for your case.
Best Regards.
STTwo-32
