BLE Scanning on single channel only ability. Can the STM32WB scan only one of the 3 channels (ch37/ch38/ch39) ?
Ofer
3 REPLIES 3
Remi QUINTIN
​It should be possible using the HCI_LE_SET_ADVERTISING_PARAMETERS command that enables the selection of the  advertising channel map ( Advertising_Channel_Map parameter). Note that this call must be done before the GAP command that triggers the scanning.
Thanks Remi
I asked about one channel scanning ability - not about one channel advertising ability.
Remi QUINTIN
​ We are not aware of any BLE command enabling the possibility to scan only 1 single channel.
At least this is not supported with our BLE stack.
