Where is the content that used to be in the touchgfx open repository?
AndrewM
Can someone tell me if/where the content that used to be in the open repository is now available? The open repository appears to have been recently wiped. https://github.com/touchgfx/touchgfx-open-repository/
I'm also curious to know why it was wiped?
Martin KJELDSEN
Chief III
I wiped it a few weeks ago.
The hope was that we would have more contributors and we ended up having to support a lot of "out-dated" examples/widgets as the framework progressed. Does that make sense?
Secret: I didn't re-write/wipe the history, so if you clone the repo it is only the last commit that wiped everything.
But officially it's not active anymore and only contains links to the doc site and the community.
/Martin
5 REPLIES 5
Martin KJELDSEN
Chief III
/Martin
AndrewM
OK, thanks for the info, yep that makes sense.
Cheers,
Martin KJELDSEN
Chief III
AndrewM
Thanks Martin, actually I'd already snaffled the repo, based on your earlier answer :beaming_face_with_smiling_eyes: :thumbs_up:
I have tried the Carousel widget, that i know is working on a project with touchGFX 4.10 do you know if there where any issues with widget with newer touchGFX versions? I am using 4.21.3.
Cheers
