2020-06-05 6:11 AM
I want to know how many fonts that can is support in my project.
So do you guys have any idea how much will be the maximum size of a font with 3 different sizes(20,40,80).
Thanks in advance
Bala
2020-06-06 12:07 AM
Hi @Bala ,
In case you are using the gcc compiler, the size can be known by looking into the map file of your application. The map file is generated by the gcc linker & stored in the folder : <project_name>/TouchGFX/build/bin.
It is a long file giving a lot of details. Look for the text "FontFlashSection", which will give you the starting address & the size of this resource.
/Jagdish Bisawa
2020-06-07 6:09 AM
Hi @Jagdish Bisawa ,
Thanks for the details.
Bala
2020-06-09 12:45 AM
And note that the linker script will only tell you the size of the glyphs that you actually use in your application, not the entire font.
