2019-05-14 1:14 AM
We intend to use a font which was installed correctly but was not listed in TouchGFX under the Font column in Typographies.
After some investigation, we found the font contains a space in its filename, e.g. "Sample Font.ttf". After removing the space and reinstalling the font it is listed correctly.
The workaround to remove the space and re-install the font works fine for now, but requires each developer to follow this step for a font that is pre-installed on our computers - hence this bug report.
2019-05-14 2:17 AM
Hi @André Sääf,
Thanks for the report. It's in our bug tracker now.
/Martin
2019-05-14 2:17 AM
Hi @André Sääf,
/Martin
