Transistion to derived view class
RSchl.1
Hello
I have a View1, generated by the Designer and I can transision to this view.
Now I want to create a View2, which View1 is it's base class and transistion to this View2.
How can I do this?
Thanks, Regards RS
1 REPLY 1
Martin KJELDSEN
Chief III
There's no way currently to have define a base view in the designer for another view.
If you search this community i've shared an example of how you can achieve base-views manually, and i'm also (sometimes) working a bit on a tool that can do this automatically for you. It's a temp solution until it becomes a part of TouchGFX designer.
/Martin
