2024-09-01 11:03 PM
STM32CubeIDE- 1.13.2
TouchGFX - 4.24.0
STM32F423ZHT6 evaluation board has lack of LTDC and DMA2D compare to other STM32F4 series. I want to turn on the LCD panel (NHD-2.8-240320AF-CSXP-FCTP-ND) and it display the white background. Can any one please guide me? How to do it.
2024-09-03 4:38 AM
I recommend following our guide : board-introduction .
Here is the part where we control the screen and test it : display-internal
2024-09-03 4:59 AM
Okay. Thanks for your reply @GaetanGodart
2024-09-03 5:15 AM
I stuck in LCD interface. In my MCU (STM32F423ZHT6) doesn't have LTDC and DMA2D. How can I interface with LCD display? If any other method to interface with my LCD panel and MCU. Let me know.
Can I implement the SPI interface for LCD.
I have old project (Smart lock) without touchGFX designer. Here, they using LCD touch for Number pad. But the problem is there is no specific .ioc file. They use ST7789h2 driver.
So, I want implement a effective GUI application by using TouchGFX.
2024-09-03 11:27 PM
Today I create a project on STM32F412- Disco. It generate the Makefile can I edit it for my STM32F413ZH board.
If it is possible mans can you help me.
# Helper macros to convert spaces into question marks and back again
e :=
sp := $(e) $(e)
qs = $(subst ?,$(sp),$1)
sq = $(subst $(sp),?,$1)
# Get name of this Makefile (avoid getting word 0 and a starting space)
makefile_name := $(wordlist 1,1000,$(MAKEFILE_LIST))
# Get path of this Makefile
makefile_path := $(call qs,$(dir $(call sq,$(abspath $(call sq,$(makefile_name))))))
# Get path where the Application is
application_path := $(call qs,$(abspath $(call sq,$(makefile_path)..)))
# Change makefile_name to a relative path
makefile_name := $(subst $(call sq,$(application_path))/,,$(call sq,$(abspath $(call sq,$(makefile_name)))))
# Get relative path to makefile from application_path
makefile_path_relative := $(subst $(call sq,$(application_path))/,,$(call sq,$(abspath $(call sq,$(makefile_path)))))
# Get path to Middlewares
touchgfx_middlewares_path := gcc/Middlewares
cubemx_middlewares_path := Middlewares
# Get path to Drivers
Drivers_path := Drivers
# Get OS path
touchgfx_os_path := $(touchgfx_middlewares_path)/Third_Party/FreeRTOS
cubemx_os_path := $(cubemx_middlewares_path)/Third_Party/FreeRTOS
# Get identification of this system
ifeq ($(OS),Windows_NT)
UNAME := MINGW32_NT-6.2
else
UNAME := $(shell uname -s)
endif
use_bsp_driver := 0
float_abi := hard
board_name := STM32F412G-DISCO
platform := cortex_m4f
cpp_compiler_options_local := -DUSE_HAL_DRIVER -DSTM32F412Zx
c_compiler_options_local := -DUSE_HAL_DRIVER -DSTM32F412Zx
.PHONY: all clean assets flash intflash
all: $(filter clean,$(MAKECMDGOALS))
all clean assets:
@cd "$(application_path)" && $(MAKE) -r -f $(makefile_name) -s $(MFLAGS) _$@_
flash intflash: all
# Directories containing application-specific source and header files.
# Additional components can be added to this list. make will look for
# source files recursively in comp_name/src and setup an include directive
# for comp_name/include.
components := TouchGFX/gui target TouchGFX/generated/gui_generated
touchgfx_generator_components := TouchGFX/target TouchGFX/App
cubemx_components := Core Drivers/STM32F4xx_HAL_Driver
# Location of folder containing bmp/png files.
asset_images_input := TouchGFX/assets/images
# Location of folder to search for ttf font files
asset_fonts_input := TouchGFX/assets/fonts
# Location of folder where the texts.xlsx is placed
asset_texts_input := TouchGFX/assets/texts
build_root_path := TouchGFX/build
object_output_path := $(build_root_path)/$(board_name)
binary_output_path := $(build_root_path)/bin
# Location of output folders where autogenerated code from assets is placed
asset_root_path := TouchGFX/generated
asset_images_output := $(asset_root_path)/images
asset_fonts_output := $(asset_root_path)/fonts
asset_texts_output := $(asset_root_path)/texts
#include application specific configuration
include $(application_path)/TouchGFX/config/gcc/app.mk
# corrects TouchGFX Path
touchgfx_path := ${subst ../,,$(touchgfx_path)}
os_source_files := \
$(cubemx_os_path)/Source/croutine.c \
$(cubemx_os_path)/Source/list.c \
$(cubemx_os_path)/Source/queue.c \
$(cubemx_os_path)/Source/tasks.c \
$(cubemx_os_path)/Source/timers.c \
$(cubemx_os_path)/Source/CMSIS_RTOS_V2/cmsis_os2.c
os_include_paths := \
$(cubemx_os_path)/Source/include \
os_source_files += \
$(touchgfx_os_path)/Source/portable/MemMang/heap_4.c \
$(touchgfx_os_path)/Source/portable/GCC/ARM_CM4F/port.c
os_include_paths += \
ifeq ($(UNAME), Linux)
imageconvert_executable := $(touchgfx_path)/framework/tools/imageconvert/build/linux/imageconvert.out
fontconvert_executable := $(touchgfx_path)/framework/tools/fontconvert/build/linux/fontconvert.out
else
imageconvert_executable := $(touchgfx_path)/framework/tools/imageconvert/build/win/imageconvert.out
fontconvert_executable := $(touchgfx_path)/framework/tools/fontconvert/build/win/fontconvert.out
stldr := N25Q128A_STM32412G-DISCO.stldr
include $(application_path)/gcc/include/cube_programmer.mk
endif
target_executable := target.elf
target_hex := target.hex
assembler := arm-none-eabi-gcc
assembler_options += \
-g \
-fno-exceptions\
$(no_libs) -mthumb -mno-thumb-interwork \
-Wall
c_compiler := arm-none-eabi-gcc
c_compiler_options += \
-g \
-mthumb -fno-exceptions \
-mno-thumb-interwork -std=c99 \
$(no_libs) \
-Os -fno-strict-aliasing -fdata-sections -ffunction-sections
cpp_compiler := arm-none-eabi-g++
cpp_compiler_options += \
-g -mthumb \
$(no_libs) \
-mno-thumb-interwork -fno-rtti -fno-exceptions \
c_compiler_debug_options += \
-g -mthumb \
$(no_libs) \
-O0 -fno-strict-aliasing -fdata-sections -ffunction-sections
linker := arm-none-eabi-g++
linker_options += \
-g -Wl,-static -mthumb $(no_libs) -mno-thumb-interwork \
-fno-exceptions -specs=nosys.specs -fno-rtti \
-Os -fno-strict-aliasing -Wl,--gc-sections
objcopy := arm-none-eabi-objcopy
archiver := arm-none-eabi-ar
strip := arm-none-eabi-strip
# Additional toolchain configuration for Cortex-M4 targets.
float_options := -mfpu=fpv4-sp-d16
ifneq ("$(float_abi)","hard")
float_options += -mfloat-abi=softfp
else
float_options += -mfloat-abi=hard
endif
assembler_options += -mcpu=cortex-m4 -march=armv7e-m -Wno-psabi $(float_options) -DCORE_M4 -D__irq=""
c_compiler_options += -mcpu=cortex-m4 -march=armv7e-m -Wno-psabi $(float_options) -DCORE_M4 -D__irq=""
cpp_compiler_options += -mcpu=cortex-m4 -march=armv7e-m -Wno-psabi $(float_options) -DCORE_M4 -D__irq=""
c_compiler_debug_options += -mcpu=cortex-m4 -march=armv7e-m -Wno-psabi $(float_options) -DCORE_M4 -D__irq=""
linker_options += -mcpu=cortex-m4 -march=armv7e-m -Wno-psabi $(float_options)
#include everything + specific vendor folders
framework_includes := $(touchgfx_path)/framework/include
#this needs to change when assset include folder changes.
all_components := $(components) \
$(asset_fonts_output) \
$(asset_images_output) \
$(asset_texts_output)
#keep framework include and source out of this mess! :)
include_paths := $(library_includes) \
$(foreach comp, $(all_components), $(comp)/include) \
$(foreach comp, $(cubemx_components), $(comp)/Inc) \
$(foreach comp, $(touchgfx_generator_components), $(comp)/generated) \
$(framework_includes) \
$(source_Middlewares_paths) \
source_paths = $(foreach comp, $(all_components), $(comp)/src) \
$(foreach comp, $(cubemx_components), $(comp)/Src) \
# Finds files that matches the specified pattern. The directory list
# is searched recursively. It is safe to invoke this function with an
# empty list of directories.
# Param $(1): List of directories to search
# Param $(2): The file pattern to search for
define find
$(foreach dir,$(1),$(foreach d,$(wildcard $(dir)/*),\
$(call find,$(d),$(2))) $(wildcard $(dir)/$(strip $(2))))
endef
unexport find
fontconvert_ttf_lower_files := $(call find, $(asset_fonts_input), *.ttf)
fontconvert_ttf_upper_files := $(call find, $(asset_fonts_input), *.TTF)
fontconvert_otf_lower_files := $(call find, $(asset_fonts_input), *.otf)
fontconvert_otf_upper_files := $(call find, $(asset_fonts_input), *.OTF)
fontconvert_bdf_lower_files := $(call find, $(asset_fonts_input), *.bdf)
fontconvert_bdf_upper_files := $(call find, $(asset_fonts_input), *.BDF)
fontconvert_font_files := \
$(fontconvert_ttf_lower_files) \
$(fontconvert_ttf_upper_files) \
$(fontconvert_otf_lower_files) \
$(fontconvert_otf_upper_files) \
$(fontconvert_bdf_lower_files) \
$(fontconvert_bdf_upper_files)
source_files := $(call find, $(source_paths),*.cpp)
c_source_no_opt_files :=
c_source_no_opt_files += $(call find, $(source_paths), stm32l4xx_hal_qspi.c)
board_c_files :=
board_cpp_files :=
board_include_paths := \
Drivers/CMSIS/Device/ST/STM32F4xx/Include \
Drivers/CMSIS/Include \
Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS \
Drivers/BSP/Components/Common
ifeq ($(use_bsp_driver), 1)
board_c_files += \
$(Drivers_path)/BSP/STM32412G-Discovery/stm32f412g_discovery.c \
$(Drivers_path)/BSP/STM32412G-Discovery/stm32f412g_discovery_qspi.c \
$(Drivers_path)/BSP/STM32412G-Discovery/stm32f412g_discovery_ts.c \
$(Drivers_path)/BSP/STM32412G-Discovery/stm32f412g_discovery_lcd.c
board_c_files += \
$(Drivers_path)/BSP/Components/ls016b8uy/ls016b8uy.c \
$(Drivers_path)/BSP/Components/ls016b8uy/stm32f4xx_hal_uart.c
board_include_paths += $(Drivers_path)/BSP/STM32412G-Discovery
c_compiler_options_local += -DUSE_BSP_DRIVER -DHAL_UART_MODULE_ENABLED
endif
asm_source_files := $(makefile_path_relative)/startup_stm32f412zgtx.s
include_paths += platform/os $(board_include_paths) $(os_include_paths)
c_source_files := $(filter-out $(c_source_no_opt_files),$(call find, $(source_paths),*.c)) $(os_source_files) $(board_c_files)
source_files += $(board_cpp_files)
object_files := $(source_files) $(c_source_files)
# Start converting paths
object_files := $(object_files:$(touchgfx_path)/%.cpp=$(object_output_path)/touchgfx/%.o)
object_files := $(object_files:%.cpp=$(object_output_path)/%.o)
object_files := $(object_files:$(Middlewares_path)/%.c=$(object_output_path)/Middlewares/%.o)
object_files := $(object_files:$(Drivers_path)/%.c=$(object_output_path)/Drivers/%.o)
object_files := $(object_files:%.c=$(object_output_path)/%.o)
dependency_files := $(object_files:%.o=%.d)
object_asm_files := $(asm_source_files:%.s=$(object_output_path)/%.o)
object_asm_files := $(patsubst $(object_output_path)/%,$(object_output_path)/%,$(object_asm_files))
object_no_opt_files := $(c_source_no_opt_files:%.c=$(object_output_path)/no_opt_files/%.o)
object_no_opt_files := $(patsubst $(object_output_path)/%,$(object_output_path)/%,$(object_no_opt_files))
textconvert_script_path := $(touchgfx_path)/framework/tools/textconvert
textconvert_executable := $(call find, $(textconvert_script_path), *.rb)
text_database := $(asset_texts_input)/texts.xlsx
libraries := touchgfx
else
libraries := touchgfx-float-abi-hard
endif
library_include_paths := $(touchgfx_path)/lib/core/$(platform)/gcc
.PHONY: _all_ _clean_ _assets_ _flash_ _intflash_ generate_assets build_executable
# Force linking each time
.PHONY: $(binary_output_path)/$(target_executable)
_all_: generate_assets
# if ExtFlashSection or FontFlashSection is detected inside the executable, enable external flash
flash_section_count := 0
elf_filename := "$(application_path)/$(binary_output_path)/$(target_executable)"
ifeq ($(shell test -e $(elf_filename) && echo -n has_elf_file),has_elf_file)
flash_section_count := $(shell readelf -S $(elf_filename) | grep FlashSection | wc -l)
endif
ifeq ($(shell test $(flash_section_count) -gt 0; echo $$?),0)
_flash_: _extflash_
else
_flash_: _intflash_
endif
include $(application_path)/gcc/include/flash_sections_int_ext.mk
generate_assets: _assets_
@$(MAKE) -f $(makefile_name) -r -s $(MFLAGS) build_executable
build_executable: $(binary_output_path)/$(target_executable)
$(binary_output_path)/$(target_executable): $(object_files) $(object_no_opt_files) $(object_asm_files)
@echo Linking $(@)
@mkdir -p $(@D)
@mkdir -p $(object_output_path)
@$(file >$(build_root_path)/objects.tmp) $(foreach F,$(object_files),$(file >>$(build_root_path)/objects.tmp,$F))
@$(linker) \
$(linker_options) -T $(makefile_path_relative)/STM32F412ZGTX_FLASH.ld -Wl,-Map=$(@D)/application.map $(linker_options_local) \
$(patsubst %,-L%,$(library_include_paths)) \
@$(build_root_path)/objects.tmp $(object_no_opt_files) $(object_asm_files) -o $@ \
-Wl,--start-group $(patsubst %,-l%,$(libraries)) -Wl,--end-group
@rm -f $(build_root_path)/objects.tmp
@echo "Producing additional output formats..."
@echo " target.hex - Combined internal+external hex"
@$(objcopy) -O ihex $@ $(@D)/target.hex
@echo " intflash.elf - Internal flash, elf debug"
@$(objcopy) --remove-section=ExtFlashSection $@ $(@D)/intflash.elf 2>/dev/null
@echo " intflash.hex - Internal flash, hex"
@$(objcopy) -O ihex --remove-section=ExtFlashSection $@ $(@D)/intflash.hex
# re-enable if extflash binaries are required in your workflow
# @echo " extflash.bin - External flash, binary"
# @$(objcopy) -O binary --only-section=*FlashSection $@ $(@D)/extflash.bin
$(object_output_path)/no_opt_files/%.o : %.c TouchGFX/config/gcc/app.mk
@echo [No OPT] Compiling $<
@mkdir -p $(@D)
@$(c_compiler) \
-MMD -MP $(c_compiler_debug_options) $(c_compiler_options_local) $(user_cflags) \
$(patsubst %,-I%,$(include_paths)) \
-c $< -o $@
$(object_output_path)/touchgfx/%.o: $(touchgfx_path)/%.cpp TouchGFX/config/gcc/app.mk
@echo Compiling $<
@mkdir -p $(@D)
@$(cpp_compiler) \
-MMD -MP $(cpp_compiler_options) $(cpp_compiler_options_local) $(user_cflags) \
-c $< -o $@
$(object_output_path)/%.o: %.cpp TouchGFX/config/gcc/app.mk
@echo Compiling $<
@mkdir -p $(@D)
@$(cpp_compiler) \
-c $< -o $@
$(object_output_path)/touchgfx/%.o: $(touchgfx_path)/%.c TouchGFX/config/gcc/app.mk
@echo Compiling $<
@mkdir -p $(@D)
@$(c_compiler) \
-MMD -MP $(c_compiler_options) $(c_compiler_options_local) $(user_cflags) \
-c $< -o $@
$(object_output_path)/%.o: %.c TouchGFX/config/gcc/app.mk
@echo Compiling $<
@mkdir -p $(@D)
@$(c_compiler) \
-c $< -o $@
$(object_output_path)/%.o: %.s TouchGFX/config/gcc/app.mk
@echo Compiling ASM $<
@mkdir -p $(@D)
@$(assembler) \
$(assembler_options) \
$(patsubst %,-I %,$(os_include_paths)) \
-c $< -o $@
ifeq ($(MAKECMDGOALS),build_executable)
$(firstword $(dependency_files)): TouchGFX/config/gcc/app.mk
@rm -rf $(object_output_path)
-include $(dependency_files)
endif
_assets_: BitmapDatabase TextKeysAndLanguages
.PHONY: BitmapDatabase TextKeysAndLanguages
BitmapDatabase:
@$(imageconvert_executable) -r $(asset_images_input) -w $(asset_images_output)
TextKeysAndLanguages:
@mkdir -p $(asset_texts_output)/include/texts
@ruby $(textconvert_script_path)/main.rb $(text_database) $(fontconvert_executable) $(asset_fonts_output) $(asset_texts_output) $(asset_fonts_input) TouchGFX $(text_converter_options)
_clean_:
@echo Cleaning
@rm -rf $(build_root_path)
# Do not remove gui_generated
@rm -rf $(asset_images_output)
@rm -rf $(asset_fonts_output)
@rm -rf $(asset_texts_output)
# Create directory to avoid error if it does not exist
@mkdir -p $(asset_root_path)
# Remove assets folder if it is empty (i.e. no gui_generated folder)
@rmdir --ignore-fail-on-non-empty $(asset_root_path)
2024-09-05 5:53 AM
Hello @Marudhupandian ,
You have to check what the communication protocol is for your screen.
There is a lot of cheaper screens that use SPI.
We also use SPI on the STM32G071RB nucleo + GFX01M2 so you could create a new project from TouchGFX Designer to see how we used SPI there.
Otherwise, you can also look at some YouTube guides, you will most likely find a guide for your screen as ST7789h2 is a pretty common display.
I have looked and it seems you can use FMC to control it which is totally fine.
Regarding the Makefile, you should update the names from 412 to 413, check for compiler options and the linker script.
You can try this one :
e :=
sp := $(e) $(e)
# Get OS path
else
endif
use_bsp_driver := 0
float_abi := hard
board_name := STM32F413-DISCO
cpp_compiler_options_local := -DUSE_HAL_DRIVER -DSTM32F413xx
c_compiler_options_local := -DUSE_HAL_DRIVER -DSTM32F413xx
all clean assets:
flash intflash: all
else
endif
-g \
-fno-exceptions\
-Wall
-g \
$(no_libs) \
-g -mthumb \
$(no_libs) \
-g -mthumb \
$(no_libs) \
linker_options += \
else
endif
define find
endef
unexport find
board_c_files :=
board_cpp_files :=
board_c_files += \
board_c_files += \
endif
asm_source_files := $(makefile_path_relative)/startup_stm32f413xx.s
else
endif
endif
_flash_: _extflash_
else
_flash_: _intflash_
endif
@echo Linking $(@)
@mkdir -p $(@D)
@$(linker) \
$(linker_options) -T $(makefile_path_relative)/STM32F413ZGTX_FLASH.ld -Wl,-Map=$(@D)/application.map $(linker_options_local) \
