2019-03-22 12:55 AM
Hi, I'm Hill-Rom employee and working on UI software. On the device LCD screen if leaving a screen idle for a while, sometime will observe some random lines showing on screen.
Not every time idling on the same screen can reproduce the issue but when the problem comes it's always the same lines appearing on the screen. Can you help me find out the problem?
2019-04-03 01:50 AM
Could be some sort of memory contention. You have the LTDC and DMA2D accessing SDRAM at the same time, and maybe something else too?
Are you still having this problem?
/Martin
2019-03-22 05:53 AM
Hi @SLiau,
That sounds a bit tricky to debug. Can you show me a screenshot to begin with?
Thanks.
2019-04-03 01:50 AM
/Martin
2019-04-29 11:11 PM
2019-04-29 11:44 PM
Hi Shu Wa,
That's great to hear!
Best regards,
Martin
