TouchGFX Engine Stop / Resume to Save Power
Options
2021-08-18 8:32 AM
- Is there any way to stop touchgfx (with DMA2D) engine and resume back after notification.
- Stop and Resume of Touchgfx task is not a solution as the DMA streaming is running in the background. Pls confirm ?
- Start / Stop / Resume the touchgfx engine to save the power as FMC/SDRAM/QSPI will also have to stall with option? Is it possible ?
Options
2021-10-13 4:35 PM
Hello, did you ever get a resolution on this? The only way I can get TouchGFX to resume after MCU is in STOP mode is to delete / create the TouchGFX task, which is not ideal.
