touchgfx does not swap the framebuffer
zaric
the project from designer is running correctly
then,i open the .ioc with cubeMX, select the option <generate peripheral intialization as a pair of .c/.h files per periphreal >,and re-generated the code , in running, the screen display nothing and checked the value of reg <ltdc->L1CFBAR> ,that is never changed at all
8 REPLIES 8
Alexandre RENOUX
Principal
Could you provide some screenshot of your changes in CubeMX ?
/Alexandre
Martin KJELDSEN
Chief III
Did you enable double framebuffer strategy from TouchGFX Generator? =)
I did
latest progress : set a break point at <tick();>,then click the <run> ,never stop at tick() again;
Okay, so the application isn't even running. This explains why you're not swapping.
What's it doing if you break execution?
well?it just stop at tick() at first time , run,then the run button still able to click ,but not stop at tick ()
Well, what? Debug your application and check what it's doing - The interrupt to drive touchgfx (from tft controller) is probably not firing
