TouchGFX DESIGNER run simlator error
TLEE.3
Dear all.​
The phenomenon does not occur in "Generate Code", it appears in "Run Simulation".
The source is a file shared through "git", so some folders were not created.
The error that occurred in STM32cubeIDE because the folder was not created has been resolved.
Errors occurring in TouchGFX are difficult for me.
We share the error code below.
Thank you in advance.
Run Simulator
  Generate
    Done
  Generate Assets
    make -f simulator/gcc/Makefile assets -j8
    Reading ./application.config
    Done
  Post Generate
    touchgfx update_project --project-file=simulator/msvs/Application.vcxproj
    Done
  Post Generate Target
    touchgfx update_project --project-file=../reblesspro-lcd.ioc --platform=m7
    Done
  Compile
    make -f simulator/gcc/Makefile -j8
    Compiling gui/src/model/Model.cpp
    Compiling gui/src/home_screen/homeView.cpp
    Compiling gui/src/home_screen/homePresenter.cpp
    Compiling gui/src/common/FrontendApplication.cpp
    Compiling generated/gui_generated/src/common/FrontendApplicationBase.cpp
    Compiling generated/gui_generated/src/home_screen/homeViewBase.cpp
    Compiling generated/fonts/src/Font_verdana_40_4bpp_0.cpp
    Compiling generated/simulator/src/mainBase.cpp
    g++.exe: fatal error: no input files
    compilation terminated.
    /usr/bin/sh: line 2: C:TouchGFX4.16.1envMinGWmsys1.0CoreInc: command not found
    /usr/bin/sh: line 3: C:TouchGFX4.16.1envMinGWmsys1.0MiddlewaresThird_PartyFreeRTOSSourceinclude: command not found
    make[2]: *** [build/MINGW32_NT-6.2/gui/src/home_screen/homeView.o] Error 127
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/gui/src/home_screen/homeView.o' failed
    make[2]: *** Waiting for unfinished jobs....
    make[2]: *** [build/MINGW32_NT-6.2/gui/src/common/FrontendApplication.o] Error 127
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/gui/src/common/FrontendApplication.o' failed
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/gui/src/model/Model.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/gui/src/model/Model.o] Error 127
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/generated/fonts/src/Font_verdana_40_4bpp_0.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/generated/fonts/src/Font_verdana_40_4bpp_0.o] Error 127
    make[2]: *** [build/MINGW32_NT-6.2/generated/gui_generated/src/common/FrontendApplicationBase.o] Error 127
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/generated/gui_generated/src/common/FrontendApplicationBase.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/gui/src/home_screen/homePresenter.o] Error 127
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/gui/src/home_screen/homePresenter.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/generated/simulator/src/mainBase.o] Error 127
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/generated/simulator/src/mainBase.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/generated/gui_generated/src/home_screen/homeViewBase.o] Error 127
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/generated/gui_generated/src/home_screen/homeViewBase.o' failed
    generated/simulator/gcc/Makefile:149: recipe for target 'generate_assets' failed
    make[1]: *** [generate_assets] Error 2
    simulator/gcc/Makefile:35: recipe for target 'all' failed
    make: *** [all] Error 2
    Failed
  Failed
Alexandre RENOUX
Principal
Hello TLEE.3,
What's the current status ?
Your project seems a bit messy and it's also hard for me to guess anything just from looking at the error.
I suggest to recreate a clean UI project first (without the board code) and copy all the UI code/elements to the new project. Then try to Run simulator again.
/Alexandre
