2023-10-25 07:58 AM
I am working with Version 4.22.1 of the Designer since August and had no problem to generate code.
Now I suddenly get the following issue: "Generate Code | Failed"
The following text is printed in the log:
Generate Code
Generate
Done
Generate Assets
make -f simulator/gcc/Makefile assets -j8
0 [main] us 0 init_cheap: VirtualAlloc pointer is null, Win32 error 487
AllocationBase 0x0, BaseAddress 0x1050000, RegionSize 0xE0000, State 0x10000
E:\TouchGFX\4.22.1\env\MinGW\msys\1.0\bin\sh.exe: *** Couldn't reserve space for cygwin's heap, Win32 error 0
make: *** [assets] Error 1
simulator/gcc/Makefile:32: recipe for target 'assets' failed
Failed
Failed
I am not using the simulator. It seems to me that the problem only affects the simulator code generator. Right?
Can I ignore the issue then?
Any comments welcome!
2023-10-31 05:33 AM
Hello @GS1 ,
This issue is not directly related to TouchGFX. You can read about proposed solutions on this post:
https://community.st.com/t5/stm32-mcus-touch-gfx-and-gui/compilation-error-quot-couldn-t-reserve-space-for-cygwin-s-heap/td-p/247873
Hope this helps
2023-10-31 05:33 AM
Hello @GS1 ,
Hope this helps
