Timer
GMeur
Senior II
How can I simply implement a timer with TouchGFX ?
I haven't found any class to do so… Have I missed it ?
Thanks.
Martin KJELDSEN
Chief III
Hi @GMeur​,
There are no timers in TouchGFX, per se. The ::tick() method on Model.cpp will be called every VSYNC (e.g. every 16.66 ms). You can use calls to tick() to determine your internal application timing and timeouts.
