TFT LCD touch screen mapping by external keypad
Tran Minh Cong
Posted on July 12, 2018 at 07:02
Dear every body,
I'm doing project about lcd tft 7inch 800x480 and stm32f746.
Currently, i want use external keypad (or external button), not use touch screen pannel.
Example:
http://hshop.vn/products/ban-phim-ma-tran-mem-4x4
I have 1 button on LCD:
// { BUTTON_CreateIndirect, 'Browse', ID_BUTTON_0, 13, 8, 100, 20, 0, 0x0, 0 },
(x,y) =  (13,8).
width = 100.
height = 20.
=> (x,y) center = (13+100/2 = 63,8+20/2=18).
When 1 keypad or button pressed, i checked that ok.
How to mapping 1 key pressed to WM_NOTIFICATION_CLICKED event of
ID_BUTTON_0 (ID_BUTTON_0 is displayed on LCD)? After that, emwin will do something: show dialog...
Can you tell me solutions, please?
Thank you so much!
#tft-lcd-touch-screen-mapping-by-external-keypad
39 REPLIES 39
Tran Minh Cong
Posted on July 13, 2018 at 07:37
Publish your project
Tran Minh Cong
Posted on July 13, 2018 at 09:51
Oh, many thanks.
Next step, i'm hearing you tell me about:
'Up/Down button to up/down file name in list file on TREEVIEW.
Ok button to select file (name of hItem to next funtion).'
Posted on July 13, 2018 at 10:11
I would make it easier
I would create three buttons with names file1 file2 file3
& and would emulate their pressing
Posted on July 13, 2018 at 09:02
I can not open your
WindowDLG_Test.c.
using the program GUIBuilder.
You must modify this file only insert your code only between
// USER START
.....your code
// USER END
Tran Minh Cong
Posted on July 13, 2018 at 11:04
Dear you,
When you finish code, you please update link for me.
Thank you.
Posted on July 13, 2018 at 09:44
I correct your file by add this
// Initialization of 'USB'
hItem = WM_GetDialogItem(pMsg->hWin, ID_TREEVIEW_0);
hTreeItemCur = TREEVIEW_GetItem(hItem, 0, TREEVIEW_GET_LAST);
hTreeItemNew = TREEVIEW_ITEM_Create(TREEVIEW_ITEM_TYPE_NODE, ' file1.txt', 0);
TREEVIEW_AttachItem(hItem, hTreeItemNew, hTreeItemCur, TREEVIEW_INSERT_BELOW);
hTreeItemNew = TREEVIEW_ITEM_Create(TREEVIEW_ITEM_TYPE_NODE, ' file2.txt', 0);
hTreeItemNew = TREEVIEW_ITEM_Create(TREEVIEW_ITEM_TYPE_NODE, ' file3.txt', 0);
hTreeItemNew = TREEVIEW_ITEM_Create(TREEVIEW_ITEM_TYPE_NODE, ' file4.txt', 0);
// Initialization of 'OK'
Tran Minh Cong
Posted on July 13, 2018 at 11:49
Dear you,
I have finished
treeview_up() function. It is ok.
My code:
void treeview_up(void) {
WM_HWIN hTree0;
TREEVIEW_ITEM_Handle hTVI0, hTVI1;
hTree0 = WM_GetDialogItem(WM_GetFirstChild(WM_HBKWIN), ID_TREEVIEW_0);
hTVI0 = TREEVIEW_GetSel(hTree0);
if (hTVI0) {
hTVI1 = TREEVIEW_GetItem(hTree0, hTVI0, TREEVIEW_GET_PREV_SIBLING);
if (hTVI1) {
TREEVIEW_ITEM_Detach(hTVI0);
TREEVIEW_AttachItem(hTree0, hTVI0, hTVI1, TREEVIEW_INSERT_ABOVE);
TREEVIEW_SetSel(hTree0, hTVI0);
} else {
GUI_MessageBox('Item is already on top!', 'Info',
GUI_MESSAGEBOX_CF_MODAL);
WM_SetFocus(hTree0);
How to check, get text content in treeview hItem? 'file1.txt', 'file2.txt', 'file3.txt' or 'file4.txt'
char* treeview_select_file(void){
char* s_file;
WM_HWIN hTree0;
TREEVIEW_ITEM_Handle hTVI0;
TREEVIEW_ITEM_INFO ItemInfo;
if (hTVI0) {
TREEVIEW_ITEM_GetInfo(hTVI0, &ItemInfo);
if(ItemInfo.IsNode == 0){//Khong phai node
//do something to copy file name to s_file???
Posted on July 13, 2018 at 10:08
Buttons must emulate pressed on
TREEVIEW area
Tran Minh Cong
Posted on July 13, 2018 at 14:03
Dear Vitaliy Chernobay,
I have other question, i need your helps.
Content:
- I have 3 icon (circle, rectangle, triangle) image .png, .jpg, .bmp...I show on 'window dialog' or 'framewin dialog'.
Dimension of icon about 100x100 pixel.
When I get event up/down from external button,
circle/rectangle/triangle iamge will be selected.
ok event to select current to next funtion.
Can you tell me about solutions to do that?
Thank you!
