STM32F429i_Discovery with LCD load logo or image
ibrahim
Posted on September 15, 2016 at 10:10
Hello
everyone, I hope you are well.
I have a small
problem I would like to display a logo of my my university on board
but I sometimes displaying the logo ST.
I use LCD
image converter
but it does not work well to create my table to integrate it into the code.
I do not know
if ST used another converter. You can point me please.
I use BSP_LCD_DrawBitmap(...);
Thank you very much.
#stm32f429i #lcd #ili9341
29 REPLIES 29
ibrahim
Posted on September 16, 2016 at 10:32
Thank you for the answer, but after generating code in .c with BitmpCV.exe I just copy the table in my .h file
stlogo.h
#ifndef __STLOGO_H
#define __STLOGO_H
#if defined ( __ICCARM__ )
#pragma data_alignment=4
#endif
_ALIG_BEGIN Const unsigned char stlogo [2795] _ALIGN_END {
copy of the table by generating BitmpCV.exe
#endif /* __STLOGO_H */
After my main.c
#include ''stlogo.h''
int main (void){
while (1){
BSP_LCD_DrawBitmap (40, (uint8_t *) stlogo);
0690X00000605T8QAI.png With the example file STM does it work but with my table it does not work. thank you my results
http://www.mediafire.com/view/7wgy8jh8a16j7sv/IMG_20160916_105009%5b1%5d.jpg
riuson
Posted on September 16, 2016 at 12:18
Save this code to file
#ifndef __STLOGO_H
#define __STLOGO_H
#endif
$(start_block_images_table)
_ALIG_BEGIN
const
unsigned char $(doc_name_ws)[$(out_blocks_count)] _ALIGN_END {
$(out_image_data)
$(end_block_images_table)
and select it as template for images (Options -> Conversion -> Templates). I can show the rest of the settings, but I need to know the data format required by your program.
ibrahim
Posted on September 16, 2016 at 14:18
Hello
, here are the
steps
for
how I
try to do the same as
the example of
STM
1st step: I generate my
in table .c
with
BmpCVt.exe so I'll have my table soon after they are on 8bit 0xFF
and
soon
both
16bit
0xFFFF.
2nd step:
I open
my
file
stlogo.h
I brought
to STM
sample file
in STM32F4xx_DFP/2.9.0
/Projects
STM32F429I
-Discovery
/Examples /BSP/Inc
With
their
table
it works fine I displays the ST logo. but if I want to put my table and I create with BmpCVt.exe clears their table and I put my table. it gives me nothing and the display will give me any results
0690X00000605buQAA.png0690X00000605Z1QAI.png0690X00000605WcQAI.png0690X00000605WbQAI.png0690X00000605TSQAY.png
riuson
Posted on September 16, 2016 at 17:02
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6f2&d=%2Fa%2F0X0000000bse%2F.L.GX94Dv9nXxNJPDefRxPDjTxFv80TN9J_N.9rnHmE&asPdf=false
ibrahim
Posted on September 16, 2016 at 17:17
Thank you for your help,
and I want to understand the program how you generate the table with that tool and its options thank you again
riuson
Posted on September 16, 2016 at 17:30
enedis.ibrahim
This is experiment with BMP internal data format.
If the experiment
will succeed
, I made a template for LIC.
Corrected code, format R5G6B5, in attachments.
Try it and
let me know
the results.
________________
Attachments :
image.h : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzmQ&d=%2Fa%2F0X0000000bPW%2F0phSQrsQdkka9wJWKHVVotH.lXB7yXHvPJf6GN0VurU&asPdf=false
ibrahim
Posted on September 16, 2016 at 17:50
it was successful but it gave me an inverted logo with color green and orange
riuson
Posted on September 16, 2016 at 18:01
And try this attachment with inverted R/B colors.
________________
Attachments :
image.h : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzhg&d=%2Fa%2F0X0000000bPX%2Fq4JvYLn_aKuOky8355fmncF9B9R2zpg.cWEsr3iogq4&asPdf=false
ibrahim
Posted on September 16, 2016 at 18:08
How can I change color details and how do I generate a table as you did for another
logo,
you can show me
the
way
Thank you
riuson
Posted on September 16, 2016 at 18:47
See attachments here.
________________
Attachments :
2016-09-16_21-40-46.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzmL&d=%2Fa%2F0X0000000bPT%2FKLhTGSfhO9C4byRGEqlo.731H.0sPJGb0iiPAEeuhKE&asPdf=false
2016-09-16_21-40-56.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzmB&d=%2Fa%2F0X0000000bPR%2FOEcUUMQCWmF5Xs8og1G60NwX9P8lbBRTYzsZR0Brhy0&asPdf=false
2016-09-16_21-41-05.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzm6&d=%2Fa%2F0X0000000bPS%2FZwic3xzlZW8rzYWl1k9nmgahS80ue9UmXQ3_RHCilWU&asPdf=false
2016-09-16_21-41-13.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzKJ&d=%2Fa%2F0X0000000bPQ%2FktMRV4MlTkMMiyctw23deMknk7i9gBzaR2F7TdSSOjU&asPdf=false
2016-09-16_21-41-19.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzlw&d=%2Fa%2F0X0000000bPN%2FwhARxhyJ54f1wHKl57kwcOoozQ3mcxZ7wSMQ.YgnTgg&asPdf=false
enedis2.tmpl : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzlr&d=%2Fa%2F0X0000000bPO%2FIuv.zS0hCiyCQ7_YVU5Cj2DVbkLNPHs3TLyCkH44BWs&asPdf=false
stm32disco-preset-r5g6b5.xml : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzlh&d=%2Fa%2F0X0000000bPP%2FzuaiB2CaEbFtv3WG15PiOlqdLE3OPleZiFaF374lRbY&asPdf=false
