Screen Tearing
‎2020-01-29 4:00 PM
I'd like to start by saying thank you to the community, so far it has been great and I have been able to work through any issue that has come up.
A new problem has shown up today. I just started making some real headway on my project, and in doing so, I created a new screen with a scrollable container. Within that container, I have some text. When I try and scroll around it appears I have some screen tearing issues. I have attached a video of the issue.
I have read around about this issue and it seems like a double buffer could solve this issue, so I enabled the double buffer and stuffed these values based on another demo from TouchGFX:
Start Address : 0xC0000000
Start Address 2: 0xC005FA00
Enabling the double buffer didn't change anything :(
Any help/guidance would be greatly appreciated.
Processor: STM32F746BG
TouchGFX 4.13.0
STM32CubeIDE 1.2.1
Regards,
James
- Labels:
TouchGFX
‎2020-01-30 12:52 AM
This looks like more like a display configuration issue to me (e.g. Those pixel artifacts are definitely not in the framebuffer).
Can you share more information about your hardware setup and how you created this project?
/Martin
‎2020-01-30 2:09 AM
Could it be a memory bandwidth issue?
Even with double buffering you need enough bandwidth to both read the active framebuffer to the display, and write to the other buffer.
I have seen strange stuff on displays when they are not feed with enough data...
A quick test could be to set lockDMAToFrontPorch in the HAL:
lockDMAToFrontPorch(true);
‎2020-01-30 2:12 AM
It could be, definitely!
Usually, the test would be to lockDMAToFrontPorch(true); yes! It ensures that the SDRAM isn't accessed by both LTDC/DMA2D at the same time.
/Martin
‎2020-01-30 9:22 AM
I should have included more information in my initial post, apologies.
Display: RK043FN66HS-CTG
FMC, LTDC, DMA2D
I setup the project using STM32CubeIDE File->New STM32 Project and selected the STM32f746BG. I then proceeded to enable the FMC, LTDC, and DMA2D options as well as the X-CUBE-TOUCHGFX.4.13.0 additional software options.
I pretty much followed @HP​s video posted here: https://www.youtube.com/watch?v=o42r4xXOnbo
Of course my hardware has a few differences, mainly the LTDC and FMC use some alternative lines.
I do have a High Speed External clock at 8Mhz, which is different from the STM32F746-Disco boards of 25Mhz. I have adjusted the Clock Configuration in Cube to account for this.
lockDMAToFrontPorch(true) is how STM32CubeIDE and TouchGFX had initially setup in this function: void TouchGFXGeneratedHAL::initialize()
I also tried changing it to false, but the same issue persists.
I have attached my cube file for analysis.
‎2020-01-30 11:37 AM
your PLLSAI1 is not set right.
You're generating a 25MHz pixel clock. If you're using the F746-Disco board then you want something like 9.6MHz or thereabout.. I think the minimum is 8 and max is 12..
Try setting the /R to 6 and *N to 57 ish...
‎2020-01-30 2:15 PM
You are right, the timing on the LCD-TFT is way too high. I've been messing with this timing, *N on PLLSAI1 cannot be set to less than 100 without cubemx barking at me about it. I ignored the errors and what do you know! it works!
I have attached some screenshots of the "errors" that cubemx throws when I change *N and /R values.
‎2020-01-31 12:36 AM
I had a whole host of problems with just setting the values. Cube would not update the values and selecting the dropdown box was a huge pain.
Are you writing in the field? I thought it was just an output value :)
‎2020-01-31 4:46 AM
You can type into the LCD TFT field and CubeMX will attempt to back calculate all of the divisors and multipliers. It is hit or miss. In this case I manually found the proper values because CubeMX refuses to accept the values that work.
Please, don’t get me started on the drop down boxes agggggghh! Those things are a pain!!!!
It seems CubeMX wasn’t updating my HSE speed either. I dropped a 25Mhz crystal onto my board just to see if I could better match the f746 disco, and it rendered my board practically useless. It seemed like the HSE value wasn’t actually being updated. Who knows???
