qspi with touchgfx in stm32f469i dico board
Abhishek_nr
hello everyone..
i am getting problem in the stm32f469 disco board while using the QSPI along with the touchgfx, i worked previously only on Qspi with external loader what ever stm given and it worked fine but after that i configured project from tochgfx the IDE, IDE it self Enable and give the configuration some other peripheral, i am using qspi with default configuration  whatever by touchgfx IDE given itself, i am not able to write and read to External QSPI flash even though i am following same procedure what ever i followed while working without touchgfx. if i disable memory mapped mode it is going to error handler.
please some one suggest solution why the QSPI is not  working with touchgfx.
0 REPLIES 0
