Modal Window flickers when modalWindow.show() is called
Tucu
hello i have a screen where if i press a button a modal window apears with text and 2 buttons (OK) and (CANCEL) .When i call modalWindow.show() the modal window apears but for 1-2 secconds it flickers . can you help me with this ? Thank you
1 REPLY 1
Hello @Tucu ,
Could you please provide more information on what board or MCU you are using for your development?
What version of TouchGFX are you using?
Is the flickering happening once or does it continue when it starts?
Could you please try a similar implementation to the Modal Window example in the TouchGFX designer to test if the flickering happens?
Modal Window ExampleModal Window Example
Mohammad MORADI
