Is TextArea::getBaselineY() not implemented by desing ?
ferro
Lead
As the TextArea::setBaselineY() is not mirrored with a getter TextArea::getBaselineY() I wonder whether it is a design decision or simply overlook.
Osman SOYKURT
Hello ferro,
Actually the setBaseline() function will move the widget entirely, so getting a value like this would not be different than getting your widget Y-position. This is not the same for the setIndentation() function however, where only the text will "move" and not the widget.
/Osman
Osman SOYKURT
ferro
Lead
Hi @Osman SOYKURT​
"Actually the setBaseline() function will move the widget entirely"
Yes ! I realized that while tinkering with a vertical alignment.
"getting a value like this [ getBaseline () ] would not be different than getting your widget Y-position"
I think the hypothetical getBaseline () sbould differ from getY() by getTypedText().getFont()->getBaseline() as
//TextArea.hpp
virtual void TextArea::setBaselineY(int16_t baselineY)
    setY(baselineY - getTypedText().getFont()->getBaseline());
