is it possible to connect a camera to STM32L4R9I-EVAL board? if so how and what camera module ?
vini
4 REPLIES 4
I will look at a board later, highlights say it has 8 to 14 bit DCMI, but don't recall it shipping with one or using STs header like other EVAL boards.​
vini
ok, please check and let me know. appreciate your help
Only mention of camera in front-page paragraph, no other headers or reference to DCMI.
You could perhaps go over the expansion pin headers for DCMI pins, but heavier lift than I'm up for.
https://www.st.com/content/ccc/resource/technical/document/user_manual/group0/3d/4e/40/cd/99/9f/42/94/DM00407907/files/DM00407907.pdf/jcr:content/translations/en.DM00407907.pdf
https://www.st.com/en/evaluation-tools/stm32l4r9i-eval.html
@Imen DAHMEN​ @Amel NASRI​ can you check the manuals and landing page to see if the camera reference has any additional support, or just from other EVAL board docs.
Imen.D
Hello @vini​ ,
On the STM32L4R9I-Eval board, we do not have a dedicated connector for the camera. So, it required to check the DCMI pins/alternate function and added manually a module supported a parallel camera interface.
The AN5020 “Application note Digital camera interface (DCMI) for STM32 MCUs�?, mentioned some camera modules that are compatible with the STM32 DCMI, as ArduCAM.
Best Regards,
Imen
Imen
