Is it possible to change the image color?
  • December 4, 2024
  • 1 reply
  • 573 views
Is it possible to change the color of the image or icon I created via GUI or code? The color of the .svg icons in Touchgfx's own native files can be changed via GUI, but I could not change the color of the .svg or .png images I created. There is no function called image.setcolor in the code. Is there a way to change the color of the image I created?
Best answer by LouisB
Hello @hamzatamer ,
No it's not possible, svgs and images are compiled when generating the code.
You could use a dynamic bitmap  but it requires you to write your own code to perform that.
BR,
Louis B.
1 reply
LouisBBest answer
Hello @hamzatamer ,
BR,
Louis B.
Louis BOUDOST Software Engineer | TouchGFX
