Is it possible to assign the text alignment (left, center, right) through code? If yes, how?
Iswarya
Martin KJELDSEN
Chief III
Hi @Iswarya​,
That's not possible i'm affraid. You specify the alignment through the text sheet alone.
/Martin
Martin KJELDSEN
Chief III
Hi @Iswarya​,
/Martin
Hi @Martin KJELDSEN​ ,
Can't be changed it by editing "TypedTextDatabase" file?
Youssef
@youssef.amimi​,
Yes, you can do that (in a way) :) But this value also comes from the text-sheet. When you re-generate your assets this file would get overwritten, and you'd have to compile the application every time you change it.
/Martin
