In Appearance the text color shows full color even with a 4 bit gray display as the device, how does that work?
KevinA
The display is a 296X128 ePaper display with 4 bit grayscale or 16 shades of gray, why didn't the color pallet switch to gray scale?
Romain DIELEMAN
As I wrote in another post thank you for reporting this. We will try to fix it for the next release.
For now you will see when running the simulator or on target that this will not impact your project. You can use the color palet and stick to the far left values of it to "have" a greyscale palet.
/Romain
