I get an error just creating a new project
‎2020-06-01 8:54 PM
environment
TouchGFX4.12.3
Select STM32F746G Discovery Kit in APPLICATION TEMPLATE
Select Blank UI in UI TEMPLATE and create
Creation of TouchGFX Application failed.
Why?
How can I check the error log?
Thank you.
- Labels:
STM32F7 Series
TouchGFX
‎2020-06-01 11:38 PM
Hi @Ebun.1​ ,
I have been using TouchGFX Designer V 4.13.0 & have not come across such an issue. This version has a button on the bottom right that can display the log of activities.
May be you can try to upgrade to the latest version & do away with this proble.
/Jagdish Bisawa
Hi @Ebun.1​ ,
/Jagdish Bisawa
‎2020-06-02 12:01 AM
