I generated my first test project with TouchGfx. It compiles correctly but I don't see any images on the display. Maybe it does added some code to display the first screen?
FLaga.1
MM..1
Chief III
Your code is empty off display init. TGFX is memory gui manager , hw is on your code.
LTDC init seems good, but need minimum call in user part unreset display pin and turn on backlight.
Create some example on TGFX and read BSP codes.
