I am trying to simulate the OoB Online application for STM32H750.
I can simulate in Designer V4.12.3 but 'Run Simulator' as well as 'Generate Code' generates an error in Designer 4.13.
See details.
2020-02-05 9:29 PM
Done
Post Generate
touchgfx update_project --project-file=../EWARM/application.ewp && touchgfx update_project && touchgfx update_project --project-file=simulator/msvs/Application.vcxproj
No value provided for required options '--project-file'
Failed
Failed
Running the Application.sln gives build errors with
Severity Code Description Project File Line Suppression State
Error LNK2019 unresolved external symbol "public: __thiscall HallwayScreenViewBase::HallwayScreenViewBase(void)" (??0HallwayScreenViewBase@@QAE@XZ) referenced in function "public: __thiscall HallwayScreenView::HallwayScreenView(void)" (??0HallwayScreenView@@QAE@XZ) Application C:\TouchGFXProjects\MyApplication_3\Projects\TouchGFX\simulator\msvs\hallwayScreenView.obj 1
and
Error LNK2019 unresolved external symbol "public: virtual void __thiscall HallwayScreenViewBase::setupScreen(void)" (?setupScreen@HallwayScreenViewBase@@UAEXXZ) referenced in function "public: virtual void __thiscall HallwayScreenView::setupScreen(void)" (?setupScreen@HallwayScreenView@@UAEXXZ) Application C:\TouchGFXProjects\MyApplication_3\Projects\TouchGFX\simulator\msvs\hallwayScreenView.obj 1
STM32H7 Series
TouchGFX
2020-02-17 2:30 AM
The resulting build errors are because the post-generate fails (it cannot update your project with HallWayScreenView.cpp.
I'm not sure what happened to your post generate command, but open your .touchgfx file and remove this part
It should work then, updating EWARM and MSVS projects.
/Martin
