How to install templates offline?
Asantos
My office computer only have internet access via virtual machine, So i can't download the templates in the TouchGFX Designer.
How to install the STM32F746G-DISCO template offline?
Martin KJELDSEN
Chief III
Place AT package files into app/packages of your designer install. e.g. for mine:
D:\TouchGFX\4.13.0\app\packages
You will have to request them, for now, to get the files. Which ones do you need?
/Martin
6 REPLIES 6
HHarj.1
USB memory stick?
Asantos
My problem is were to download the template files and know in what directories the files should be transferred to.
Martin KJELDSEN
Chief III
/Martin
Asantos
Martin,
I need the last template for the "STM32F746G Discovery Kit".
Another PC with the template installed, in the directory C:\TouchGFX\4.13.0\app\packages, it only have the files:
BlankUI-2.0.0.tpa
Simulator-2.0.0.tpa
Martin KJELDSEN
Chief III
The two templates that you're referring to are simply the two default packages that the designer comes installed with.
The actual packages you've downloaded are inside %APPDATA%/Touchgfx-4.13.0/Downloads
Martin KJELDSEN
Chief III
