How to display superscript in feet cubic?
‎2021-11-22 9:12 PM
I want to display the unit of volume as ft³. How can I do this in text widget of TouchGFX Designer?
- Labels:
TouchGFX
‎2021-11-23 10:25 AM
It probably also needs to be added to Wildcard Characters list in Typographies in the designer, otherwise it will display as ?
‎2021-11-23 9:48 AM
You try use Alt+0179 m³
‎2021-11-23 10:41 AM
Too simply Ctrl C Ctrl V work, simple place it to Single use or Resource Texts size and font, then is added automatic, dont need list in Typogra...
‎2021-11-23 12:03 PM
You are correct, assuming they aren't going to use it in wildcards. Adding it to Typographies covers all use cases.
‎2021-11-25 6:36 PM
Thanks folks, so I just added '³' to Typography and copy paste the ft³ to my code, and it works as expected.
