How to change the size of the standard widgets to a custom size?
Eddy V
Beginner question here: The widgets that can be selected in TouchGFX designer have standard sizes (small, medium, large). How can i create a widget with a non-standard size? Is there an example for this?
Eddy V
I figured it out. There is actually an article about this in the knowledge base.
Eddy
ATek.1
Hi @Eddy V​
I have this problem too.
could you please tell me which article is related to the issue??
thanks in advance;)
This question is quite old, TouchGFX has greatly changed since. What are you trying to do exactly ? What widget are you working with ? Here is a link to the official documentation, hope this will help you understand how to work with TouchGFX and the different widgets.
/Romain
