how to change the animation in stm32f7?
SNC.1
i have tried by using touchGFX, when i press the "target run" it's showing failed, but when i do "Run simulator", There is no error in it.
4 REPLIES 4
Yoann KLEIN
Hello @SNC.1​,
Could you provide more information about the error message ?
Did you start your project with a TouchGFX Board Setup (from TouchGFXDesigner), or from STM32CubeMX ?
Did you ensure that your board is correctly connected and powered ?
/Yoann
Yoann KLEIN
i started my project with TouchGFXDesigner.
Sorry for the delay,
Are you sure the board is correctly connected and powered ?
/Yoann
Yoann KLEIN
Osman SOYKURT
Hello @SNC.1,
Do you have STM32CubeProgrammer Software installed on your computer? Running on target with TouchGFX Designer requires STM32CubeProgrammer software so if you don't have it, you'll need to install it.
/Osman
Osman SOYKURT
