How do I repeat a sequence of Interactions?
wired
Senior III
I have a screen where I want to repeat a sequence of widget moves once a button is pressed, and then stop it when another button is pressed. I have an Interaction triggered by the 1st button press that moves the widget down (MoveWidgetDown) and another Interaction that resets the widget to the original position (ResetWidget) that is triggered by the completion of MoveWidgetDown. But I don't see a way to retrigger MoveWidgetDown to repeat the process. Is there a way to accomplish this within the Designer? If not, does anyone have any suggestions for how to do this using external code?
0 REPLIES 0
