2022-05-09 05:17 AM
2022-05-10 12:36 AM
Hello @Jloda.1 ,
To switch from a screen to another programmatically, you have to use one of the "Switch screen" functions (e.g. gotoScreen2ScreenSlideTransitionEast()).
I recommend you to call those functions from your ScreenView.cpp class.
I already answered to a similar question a few months ago, please check it.
Please let me know if it helped you,
/Yoann
2022-05-11 04:39 AM
So here is what I have done until now:
I have a very big GUI with 20 to 30 screens, So to generate functions for changing screens I have added blank interaction for screen change for all screens in one screen then I have included that screen's header in model.
then for every button press I have pushed it into a queue and process that in main.c and then using another queue it has gone to the model and using switch case I have changed the screen.
but the screen transition seems laggy and slow since model only runs at rendering of frame I want to change screen from main.c but the touch gfx file are .cpp so it gives error if I include those files in main.c
So I want a way to change the screens from main.c
