gfx::Screen : access to gfx::Box __background {} instance color property from Gfx Designer
‎2024-02-16 3:51 AM
Hi GFX Team,
Could you possibly add access to colour of autogenerated __background gfx::Box please ?
Ferro
TouchGFX Designer
‎2024-02-20 6:22 AM
Hello @ferro ,
I transferred your request.
The team will see if they want to implement that feature for the incoming versions. :)
Software engineer at ST (TouchGFX)
‎2024-02-20 6:22 AM
Hello @ferro ,
‎2024-03-01 1:20 AM
Hello @ferro ,
The feature has been discussed with the team. Unfortunately, it is not a priority at the moment as there is a workaround by adding your own box as background.
