Example of a ClickListener?
Roger.ch
How does this work with a ClickListener?
I have a view with 10 custom containers. How can I tell the view when a custom container has been pressed and which one? Do you have a simple example?
Regards, Roger
FBL
Hello @Roger.ch
Did you check this? Mixins | TouchGFX Documentation
You can find examples of implementation in Demos
Best regards,
FBL
FBL
Hello @Roger.ch
Best regards,
FBL
Hi F.Belaid
Thank you very much for your tip. Unfortunately I had not found the example. But it looks good.
I will have a look at it tomorrow.
Best regards, Roger
Hello, I'm an amateur Touchgfx user.
I've accomplished many difficult tasks with Touchgfx, but I'm desperate for a very simple one.
I want to set an output port high for the duration of a keystroke. I used the ClickListener instructions in the program, but they didn't work. I'm using the Stm32h7b3i Evk, and the definitions in the base file don't match those on the https://support.touchgfx.com/docs/development/ui-development/touchgfx-engine-features/mixins page. The program is giving an error.
Could you please provide a link to a sample program?
