Example of a ClickListener?
‎2023-09-21 6:05 AM
How does this work with a ClickListener?
I have a view with 10 custom containers. How can I tell the view when a custom container has been pressed and which one? Do you have a simple example?
Regards, Roger
TouchGFX
‎2023-09-21 6:45 AM
Hello @Roger.ch
Did you check this? Mixins | TouchGFX Documentation
You can find examples of implementation in Demos
‎2023-09-21 6:45 AM
Hello @Roger.ch
‎2023-09-21 9:20 AM
Hi F.Belaid
Thank you very much for your tip. Unfortunately I had not found the example. But it looks good.
I will have a look at it tomorrow.
Best regards, Roger
