Cutout irregular shape image
Trevor Jones
I have a product image that is not square,
how can I cut out the white background, within GFXdesigner?
Martin KJELDSEN
Chief III
You can't from within the designer, but you can use your favorite image editor to replace white with full transparency (magic wand + select white + delete?). This will for most editors introduce an alpha channel in your pixels and TouchGFX image converter will interpret this and generate pixel data for an ARGB8888 image.
/Martin
Martin KJELDSEN
Chief III
/Martin
Trevor Jones
will work with that, thanks
