compatibility of stm32h735g-dk with qt designer
‎2024-11-15 5:30 AM
Hi, I wanted to know is it possible to use QT designer (with stm32h735g-dk) for GUI instead of TouchGFX.
Thanks,
- Labels:
TouchGFX
‎2024-11-15 6:17 AM - edited ‎2024-11-19 2:51 AM
See that video https://www.youtube.com/watch?v=lVCbQZIfCIk
and check.
Otherwise, as QT is not the frame work provided by ST, you need to contact them directly: https://www.qt.io/contact-us.
Hope it helps.
and check.
Hope it helps.
‎2024-11-15 6:37 AM
https://doc.qt.io/qt-6/supported-platforms.html
whence https://doc.qt.io/QtForMCUs-2.8/index.html
whence Forum for Qt on MCUs: https://forum.qt.io/category/62/qt-for-mcus
‎2024-11-19 2:41 AM
See also:
