Availability of the library's core source files
ALiar.1
It appears that not all declared methods are implemented in the provided header and source files. Some methods like HAL::flushFrameBuffer, are apparently implemented only in the core static libraries. Is there any plan to release the source code of these libraries?
Martin KJELDSEN
Chief III
No plan, no.
In the case of flushFrameBuffer, this is a method you will overwrite. It does nothing in its default implementation =) It gets called after endFrame() and lets you transfer a block of memory (determined through the Rect argument that indicates which part of the framebuffer was updated) to a serial display. It's a hook that the user implements.
/Martin
