add function 'setAlignment ()' to set text alignment in TextArea widget
ferro
Lead
Dear Gfx Team,
Could you please add function 'setAlignment ( touchgfx::Alignment align )' to set text alignment in TextArea widget ?
This would override what is defined in 'typedText_database_XXX[]' arrays in TypedTextDatabase.cpp.
Thank you
GaetanGodart
Hello @ferro ,
We will discuss about this feature with the team!
Gaetan Godart
Software engineer at ST (TouchGFX)
4 REPLIES 4
GaetanGodart
Hello @ferro ,
Gaetan Godart
GaetanGodart
Hello @ferro ,
We will add this feature in a future major release.
Gaetan Godart
Looking forward to this new feature of yours, roughly when will it be released please?
Hello @Nex-Leo ,
This require to change our textArea implementation which is a bit too static right now so do not expect it to be implemented for the current project you are working on.
If you have a specific behavior you want to achieve, we can try to work on it together.
Gaetan Godart
