stm32H743 SBSFU Can be done through CAN Protocol ?
‎2024-12-15 9:30 PM
Hi All,
I am new to SBSFU. I have gone through x-cube-sbfu getting started document in that document provide for UART- based example. can it be implemented with FD/CAN Protocol.
Regards,
Devank_J
- Labels:
STM32H7 series
‎2025-02-14 12:06 AM
Hello @Devank_J
According to information I get from technical expert, it is possible to use the X-CUBE-SBSFU solution with CAN interface. This will consist in replacing the UART YMODEM solution by a CAN solution.
Unfortunately, only the UART YMODEM solution is available and no demo planned to support other interfaces in short-term.
Here are the files which may be impacted in order to change from UART to CAN:
At SBSFU (local loader) :
Or at UserApp level:
Or at the « standalone loader » level when it is used :
Best regards,
Younes
‎2024-12-16 12:33 AM
Same question here.
‎2025-02-10 3:31 AM
Hello @Devank_J
Sorry for the delay.
A ticket is submitted internally to provide either example of guidelines how to support CAN.
Ticket number (Ticket 202646: stm32H743 SBSFU through CAN Protocol guidelines ?) (This is an internal support Ticket for Tracking not usefull for you)
Best regards
Hello @Devank_J
Best regards,
Younes
