STM32H735AGI6 RNG non working
mzenn.280
the function MX_RNG_Init fails
HAL_RNG_Init returns t.o.:
 while (HAL_IS_BIT_SET(hrng->Instance->CR, RNG_CR_CONDRST))
  if ((HAL_GetTick() - tickstart) > RNG_TIMEOUT_VALUE)
   /* New check to avoid false timeout detection in case of preemption */
   if (HAL_IS_BIT_SET(hrng->Instance->CR, RNG_CR_CONDRST))
    hrng->State = HAL_RNG_STATE_READY;
    hrng->ErrorCode = HAL_RNG_ERROR_TIMEOUT;
    return HAL_ERROR;
Try other examples..
STM32Cube_FW_H7_V1.10.0\Projects\STM32H735G-DK\Examples\RNG\RNG_MultiRNG\Src\stm32h7xx_hal_msp.c
  * @brief RNG MSP Initialization
  *        This function configures the hardware resources used in this example:
  *           - Peripheral's clock enable
  * @param hrng: RNG handle pointer
  * @retval None
void HAL_RNG_MspInit(RNG_HandleTypeDef *hrng)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48;
  RCC_OscInitStruct.PLL.PLLState= RCC_PLL_NONE;
  RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct))
    /* Initialization Error */
    while(1);
  /*Select HSI48 output as RNG clock source */
  PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RNG;
  PeriphClkInitStruct.RngClockSelection = RCC_RNGCLKSOURCE_HSI48;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct))
    while(1);
  /* RNG Peripheral clock enable */
  __HAL_RCC_RNG_CLK_ENABLE();
3 REPLIES 3
Does it need a PLL/CLK running? Are all the registers in the RND, HASH, CRYP zero? Do the clock enables stick low?
mzenn.280
I am using the code genereted by cubemx:
int main(void)
  HAL_Init() ;
  SystemClock_Config() ;
  PeriphCommonClock_Config() ;
MX_RNG_Init() ;
I think that pll and clock are running
The funnction HAL_RNG_MspInit enables HSI48, so also this clock should be ok
Beginning:
0693W00000UnW6TQAV.pngafter msp init:
here the error:
  * @retval None
    while(1);
    while(1);
