STM32CubeU5 TFM Application (UM2581) on U575
Gencay
Can we run STM32CubeU5 TFM Application (UM2581) on U575 since it has not crypto hw like U585?
Thank you in advance!
Best Regards!
Bubbles
Hi @Gencay​,
yes, crypto library will also work. TF-M needs the TrustZone isolation hardware, cryptography software implementation is a compromise that is acceptable.
BR,
J
4 REPLIES 4
Bubbles
Hi @Gencay​,
BR,
J
Gencay
Hello @JHOUD​ Thank you for your answer.
May I also ask which one does ST suggests? TF-M or X-CUBE-SBSFU?
Best Regards.
Hi, I believe X-CUBE-SBSFU package is not really a TFM. But in STM32cubeU5 package there are TFM and SBSFU applications - both for U585, so you need to replace the cryptography with library, but both are basically TF-M. Pick whichever you like more. The one called SBSFU is trying to ease transition from non-TZ SBSFU, like for former STM32L4 users, while the other is cleaner TF-M, but the difference is mostly in the application, not in the loader or boot part.
BR,
J
Anto_Ricc
Hello @Gencay;
I'm working on the same topic: porting TFM Application designed for STM32U585xx to STM32U575xx. Can you please list the steps you follow to get this?
Many thanks in advance
