report small bugs about X-CUBE-SBSFU
Antoine1
2 small bugs I encountered:
** sfu_error.c l.246
function SFU_ErrorStatus SFU_EXCPT_Check_Code(SFU_EXCPT_IdTypeDef eExceptionId)
=> missing case SFU_EXCPT_NONE
=> never returns SFU_ERROR (should be added in default case)
** When assertion is enabled in CubeMx project, compilation fails.
There's an extra line which can be removed I guess (assert_param)
cf below:
sfu_low_level_security.c  l.886
in function FU_ErrorStatus SFU_LL_SECU_SetProtectionDAP(void)
 assert_param(SFU_IS_FUNCTIONAL_STATE(eState));
Jocelyn RICARD
Hello Antoine,
thank you for your feedback. And sorry for late answer, I've just seen this post.
I will report first one.
I know second one was already raised and will be fixed in next release
Best regards
Jocelyn
