CRC computation
‎2011-01-12 4:46 AM
‎2015-11-21 5:39 AM
So you pick the guy who's post count to the forum is ONE, and hasn't posted in TWO years?
Yes, it doesn't look like he sets crc_reg in that case, probably want a crc_reg = CRC->DR Seem to think I posted a working example earlier in the thread, where it does the last byte in software. But the purpose of writing crc_reg back into the register is that it causes the math to zero it out. Please don't use the U and Ur abbreviations, you're not textingUp vote any posts that you find helpful, it shows what's working..
‎2015-11-30 1:21 PM
It looks like it depends on which part you have for bit reversal and unit sizes. This is from the app note:
I'm using the F4 part and I need byte support so it looks like the hardware doesn't quite cut it.- Mark as New
‎2015-11-30 3:53 PM
Yes, the F4/F2/F1 implementation is somewhat restrictive, but both the M3/M4 cores have a bit reversal instruction. So groups of 4 bytes can be handled directly, and the trailing bytes managed separately.The F3/F0 parts have a more flexible solution.
https://community.st.com/0D50X00009XkgXtSAJ
Edit: Fixed broken link, original post from 20-Oct-2015
‎2016-09-06 9:49 AM
Dear clive, please point me what i am doing wrong. The problem isdifferent CRC on PC and MCU.
//Calculate CRC using hardware stm32 crc modul
for
(i=4; i<64; i= i+4){
CRC->CR |= CRC_CR_RESET;
memcpy
(&temp_32, &UserRxBufferFS[i], 4);
CRC->DR = temp_32;
//Wrong as PC value
//PC side (visual studio). I use your function.
uint32_t i;
CRC_result = 0xFFFFFFFF;
for
(i=4; i<64; i = i+4){
memcpy
(&temp_32, &Output[i] , 4);
CRC_result = Crc32Fast(CRC_result, temp_32);
DWORD
Crc32Fast(
DWORD
Crc,
DWORD
Data)
static
const
DWORD
CrcTable[16] = {
// Nibble lookup table for 0x04C11DB7 polynomial
0x00000000,0x04C11DB7,0x09823B6E,0x0D4326D9,0x130476DC,0x17C56B6B,0x1A864DB2,0x1E475005,
0x2608EDB8,0x22C9F00F,0x2F8AD6D6,0x2B4BCB61,0x350C9B64,0x31CD86D3,0x3C8EA00A,0x384FBDBD };
Crc = Crc ^ Data;
// Apply all 32-bits
// Process 32-bits, 4 at a time, or 8 rounds
Crc = (Crc << 4) ^ CrcTable[Crc >> 28];
// Assumes 32-bit reg, masking index to 4-bits
// 0x04C11DB7 Polynomial used in STM32
return
(Crc);
‎2016-09-06 11:15 AM
Resetting in every iteration of the loop is probably not helpful.
Suggest you provide a test vector of the data you are pushing through the CRC and the data you are seeing on the PC and MCU side.Up vote any posts that you find helpful, it shows what's working..
‎2016-09-07 11:59 PM
THank you! Now it works fine!
- « Previous
- Next »
