X-CUBE-AWS
‎2017-10-19 7:17 PM
When I try to add the X-CUBE-AWS expansion library package to my STM32CubeMX (which has been updated to the latest version - 4.22.1) I get the error: 'This package version is not managed on this version of STM32CubeMX'.
I used the drop down menu item under Help -> Install New Libraries in the STM32CubeMX , and pointed to a local copy of the 'en.x-cube-aws.zip' file. Is this the correct way to add the
X-CUBE-AWS expansion library?
Thanks in advance.
‎2017-10-20 2:23 AM
Hi
naturelover
‌,The X-Cube-AWS package should be used on standalone and cannot be installed with STM32CubeMX.
You have jsu to download it then run the available examples . You have to refer to
http://www.st.com/resource/en/user_manual/dm003674pdf
for details.-Amel
‎2017-10-20 2:23 AM
Hi
naturelover
for details.-Amel
‎2017-10-20 4:02 PM
Hi Amel,
Thanks for the clarification. I extracted the zip file of the expansion library package,
and it appears to by intended for Windows users.
I am using the SW4STM32 IDE under Linux for my development, and I wanted to just
confirm whether the X-CUBE-AWS package can be used under Linux as well, or not,
especially since drivers, etc., are provided in the package.
thanks,
John
