2016-10-14 3:49 AM
Hi
in which folder should I store my user .c/.h files, so they are not deleted when I regenerate the Project with STM32CUBEMX? #!cubemx2016-10-14 4:11 AM
Hi dieter
Go to project>setting >code Generator tab, then select this option: ?Backup previously generated files when re-generation??The .bak extension is added to previously generated .c/.h files. Keep user code when regenerating the C code. This option applies only to user sections within STM32CubeMX generated files. It does not apply to the user files that might have been added manually or generatedvia ftl templates.?
