Where is main.h and where should i put macro code for a project CubeMx gives?
Taehyeong Gu
Posted on April 14, 2017 at 15:08
Hi. guys.
it's simple question to someone, which is not me.
Where can i find main.h from a project the CubeMX provide?
below only header files i can find are.
I have been curious when i was going to find and utilize USART_TwoBoards_Compolling example.
and there are these codes in its main.h
So i wanted to copy this code and i couldnt find proper place(main.h) to paste it.
anyway my question is where i can find main.h or other header file which contains  ''/* Exported macro------------*/ ''
of course i explore in mxconstatns.h but i thought the header file isnt for maco code.
thanks in advance.
4 REPLIES 4
Nesrine M_O
Lead II
Posted on April 14, 2017 at 16:52
Hi
kutang
Under the Inc folder in your generated project location you may find your main.h file
-Nesrine-
Posted on April 17, 2017 at 13:19
Sorry but i couldnt find main.h in the Inc folder
Should i configure something for main.h to be created?
Thanks in advance.
Posted on April 17, 2017 at 17:29
Hi
Gu.Taehyeong
Could you please share your .ioc file for check?
-Nesrine-
Posted on April 18, 2017 at 04:53
https://www.dropbox.com/s/vcajf37fqxgi6nn/TEST.ioc?dl=0
Here you can download my .oic
Thank you.
Sorry, i made a link with wrong ioc file.
I have updated it. now you can download and check it.
